프루사 슬라이서에 사용되는 변수들
Slic3r placeholders (a copy of the mauk.cc page)
Slic3r placeholders
On this page you can find a list of Slic3r placeholders or variables that can be used in the custom gcode settings
You can use multiple placeholders at a time:
M109 T[next_extruder] S[first_layer_temperature_[next_extruder]]
would generate something like
M109 T1 S190
note that the values from the Slic3r GUI are used and not values your firmware will expect.
Useful place holders
bed_temperature
M140 S[bed_temperature]
note: It will always take the value of the filament loaded in extruder_0
current_extruder
M104 S[first_layer_temperature_[current_extruder]]
note: this will not work in start gcode as the [current_extruder] placeholder is filled with the number of the last used extruder, which is nothing at startup and random at any other slicing job
M104 S[first_layer_temperature_0]
M104 S[first_layer_temperature_[next_extruder]]
first_layer_bed_temperature
M140 S[first_layer_bed_temperature]
layer_num
M117 printing layer [layer_num]
layer_z
M117 printing layer [layer_num] at [layer_z]mm
total_layer_count
M117 printing layer {layer_num+1}/[total_layer_count]
next_extruder
note: this only works in tool change gcode
previous_extruder
M104 S[first_layer_temperature_[previous_extruder]]
temperature
M109 S[temperature_0]
M109 S[temperature_[previous_extruder]]
Additional placeholders in the output file template
print_time
normal_print_time
silent_print_time
used_filament
extruded_volume
total_cost
total_weight
total_wipe_tower_cost
total_wipe_tower_filament
Less usefull place holders
avoid_crossing_perimeters
bed_shape
bottom_solid_layers
bridge_acceleration
bridge_fan_speed
M106 S[bridge_fan_speed]
-> This will put in the actual value (0-100) that was filled in, and not 0-255 .
bridge_flow_ratio
bridge_speed
brim_width
complete_objects
cooling
default_acceleration
disable_fan_first_layers
dont_support_bridges
duplicate_distance
external_fill_pattern
external_perimeter_extrusion_width
external_perimeter_speed
external_perimeters_first
extra_perimeters
extruder_clearance_height
extruder_clearance_radius
extruder_offset
extrusion_axis
extrusion_multiplier
extrusion_width
fan_always_on
fan_below_layer_time
filament_colour
filament_diameter
filament_settings_id
fill_angle
fill_density
fill_pattern
first_layer_acceleration
first_layer_extrusion_width
first_layer_height
first_layer_speed
gap_fill_speed
gcode_arcs
gcode_comments
gcode_flavor
infill_acceleration
infill_every_layers
infill_extruder
infill_extrusion_width
infill_first
infill_only_where_needed
infill_overlap
infill_speed
interface_shells
layer_height
max_fan_speed
M106 S[max_fan_speed]
max_print_speed
max_volumetric_speed
min_fan_speed
M106 S[min_fan_speed]
min_print_speed
min_skirt_length
notes
nozzle_diameter
octoprint_apikey
octoprint_host
only_retract_when_crossing_perimeters
ooze_prevention
output_filename_format
overhangs
perimeter_acceleration
perimeter_extruder
perimeters
perimeter_speed
G1 F[perimeter_speed]
-> This will put in the actual value (mm/sec) that was filled in, and not mm/min
post_process
pressure_advance
print_settings_id
printer_settings_id
raft_layers
resolution
retract_before_travel
retract_layer_change
retract_length
retract_length_toolchange
retract_lift
retract_lift_above
retract_lift_below
retract_restart_extra
retract_restart_extra_toolchange
retract_speed
seam_position
serial_port
serial_speed
skirt_distance
skirt_height
skirts
slowdown_below_layer_time
small_perimeter_speed
solid_infill_below_area
solid_infill_every_layers
solid_infill_extruder
solid_infill_extrusion_width
solid_infill_speed
spiral_vase
standby_temperature_delta
support_material
support_material_angle
support_material_contact_distance
support_material_enforce_layers
support_material_extruder
support_material_extrusion_width
support_material_interface_extruder
support_material_interface_layers
support_material_interface_spacing
support_material_interface_speed
support_material_pattern
support_material_spacing
support_material_speed
support_material_threshold
thin_walls
threads
top_infill_extrusion_width
top_solid_infill_speed
top_solid_layers
travel_speed
use_firmware_retraction
use_relative_e_distances
use_volumetric_e
vibration_limit
wipe
xy_size_compensation
z_offset
- 이전글프루사 [숨겨진 레이어층 없음(실험적)] 메뉴 21.12.13
- 다음글래티가 알려주는 큐라#6 21.09.03
옹골 작성일긋~!
