큐라로 만든 지코드파일 끝부분에 있는 정보들... > 자유게시판
댓글 1건 조회 1,565회 작성일 21-01-05 19:45
아침에 포스팅했던 엑셀 매크로를 이용해, 큐라로 슬라이싱 한 지코드 파일 끝 부분에 있는 설정정보들을 불러와 비교해 봤는데...
CR-10 Max Longer LK4 Pro
version 4 version 4
name PLA 0.2 name ET4
definition creality_cr10max definition custom
\\n[metadata]\\nposition 0 \\n[metadata]\\nposition 0
intent_category default intent_category default
setting_version 16 setting_version 16
quality_type standard quality_type draft
type quality_changes type quality_changes
\\n[values]\\nacceleration_print 3000 \\n[values]\\nacceleration_print 3000
acceleration_travel 3000 acceleration_travel 3000
bottom_layers 3
    coasting_enable True
    cool_fan_full_layer 2
infill_overlap 15 infill_overlap 15
infill_pattern gyroid infill_pattern gyroid
infill_sparse_density 10 infill_sparse_density 10
jerk_print 15 jerk_print 15.0
jerk_travel 30
material_flow 100 material_flow 100
material_flow_layer_0 100 material_flow_layer_0 100
material_initial_print_temperature =material_print_temperature material_initial_print_temperature =max(-273.15, material_print_temperature - 10)
material_print_temperature 190 material_print_temperature 190
material_print_temperature_layer_0 200 material_print_temperature_layer_0 200
raft_base_line_spacing 1.2
raft_margin 5
retraction_amount 1.5 retraction_amount 3
retraction_hop 0.3 retraction_hop 0.3
retraction_hop_enabled True retraction_hop_enabled True
retraction_speed 30
skirt_brim_minimal_length 50 skirt_brim_minimal_length 50
skirt_line_count 1 skirt_line_count 1
    speed_layer_0 20.0
speed_print 60.0 speed_print 60.0
speed_travel =150.0 if speed_print < 60 else 250.0 if speed_print > 100 else speed_print * 2.5 speed_travel 150
speed_wall_x 60.0
speed_z_hop 10
support_angle 70 support_angle 70
    support_brim_enable False
support_infill_rate 10 support_infill_rate 10
    support_roof_enable True
support_roof_density 100
support_roof_height 1
support_xy_distance 1.5 support_xy_distance 0.5
top_bottom_thickness 0.6 top_bottom_thickness 0.6
top_layers 3
    wall_0_wipe_dist 0
    wall_line_count 2
wall_overhang_angle 60 wall_overhang_angle 60
wall_overhang_speed_factor 50 wall_overhang_speed_factor 50
xy_offset_layer_0 0 xy_offset_layer_0 0
    z_seam_corner z_seam_corner_weighted
z_seam_type sharpest_corner z_seam_type sharpest_corner
\\n"], "global_quality": "[general]\\nversion 4 \\n"], "global_quality": "[general]\\nversion 4
\\n[metadata]\\nsetting_version 16 \\n[metadata]\\nsetting_version 16
\\n[values]\\nacceleration_enabled True \\n[values]\\nacceleration_enabled False
adhesion_type skirt adhesion_type skirt
    adhesion_z_offset 0
jerk_enabled True jerk_enabled True
    layer_height 0.2
layer_height_0 0.32 layer_height_0 0.32
print_sequence all_at_once print_sequence all_at_once
retraction_combing all retraction_combing all
    support_structure normal
support_enable False
support_type buildplate support_type buildplate
보시는 것처럼 한 번 비교를 해 봤다는 정도의 의미지...
별 소득이 없네요... ^^
저는 이 뒷부분에서 대부분의 설정정보를 다 얻을 수 있을 줄 알았는데...
해보니 그 결과가 예상과 다릅니다... ㅎ
ooojjan님의 댓글
ooojjan 작성일
반갑습니다
저 아시죠?^^
수고하셨습니다~^-^
