큐라로 만든 지코드파일 끝부분에 있는 정보들...
아침에 포스팅했던 엑셀 매크로를 이용해, 큐라로 슬라이싱 한 지코드 파일 끝 부분에 있는 설정정보들을 불러와 비교해 봤는데...
CR-10 Max | Longer LK4 Pro | ||
version | 4 | version | 4 |
name | PLA 0.2 | name | ET4 |
definition | creality_cr10max | definition | custom |
\\n[metadata]\\nposition | 0 | \\n[metadata]\\nposition | 0 |
intent_category | default | intent_category | default |
setting_version | 16 | setting_version | 16 |
quality_type | standard | quality_type | draft |
type | quality_changes | type | quality_changes |
\\n[values]\\nacceleration_print | 3000 | \\n[values]\\nacceleration_print | 3000 |
acceleration_travel | 3000 | acceleration_travel | 3000 |
bottom_layers | 3 | ||
coasting_enable | True | ||
cool_fan_full_layer | 2 | ||
infill_overlap | 15 | infill_overlap | 15 |
infill_pattern | gyroid | infill_pattern | gyroid |
infill_sparse_density | 10 | infill_sparse_density | 10 |
jerk_print | 15 | jerk_print | 15.0 |
jerk_travel | 30 | ||
material_flow | 100 | material_flow | 100 |
material_flow_layer_0 | 100 | material_flow_layer_0 | 100 |
material_initial_print_temperature | =material_print_temperature | material_initial_print_temperature | =max(-273.15, material_print_temperature - 10) |
material_print_temperature | 190 | material_print_temperature | 190 |
material_print_temperature_layer_0 | 200 | material_print_temperature_layer_0 | 200 |
raft_base_line_spacing | 1.2 | ||
raft_margin | 5 | ||
retraction_amount | 1.5 | retraction_amount | 3 |
retraction_hop | 0.3 | retraction_hop | 0.3 |
retraction_hop_enabled | True | retraction_hop_enabled | True |
retraction_speed | 30 | ||
skirt_brim_minimal_length | 50 | skirt_brim_minimal_length | 50 |
skirt_line_count | 1 | skirt_line_count | 1 |
speed_layer_0 | 20.0 | ||
speed_print | 60.0 | speed_print | 60.0 |
speed_travel | =150.0 if speed_print < 60 else 250.0 if speed_print > 100 else speed_print * 2.5 | speed_travel | 150 |
speed_wall_x | 60.0 | ||
speed_z_hop | 10 | ||
support_angle | 70 | support_angle | 70 |
support_brim_enable | False | ||
support_infill_rate | 10 | support_infill_rate | 10 |
support_roof_enable | True | ||
support_roof_density | 100 | ||
support_roof_height | 1 | ||
support_xy_distance | 1.5 | support_xy_distance | 0.5 |
top_bottom_thickness | 0.6 | top_bottom_thickness | 0.6 |
top_layers | 3 | ||
wall_0_wipe_dist | 0 | ||
wall_line_count | 2 | ||
wall_overhang_angle | 60 | wall_overhang_angle | 60 |
wall_overhang_speed_factor | 50 | wall_overhang_speed_factor | 50 |
xy_offset_layer_0 | 0 | xy_offset_layer_0 | 0 |
z_seam_corner | z_seam_corner_weighted | ||
z_seam_type | sharpest_corner | z_seam_type | sharpest_corner |
\\n"], "global_quality": "[general]\\nversion | 4 | \\n"], "global_quality": "[general]\\nversion | 4 |
\\n[metadata]\\nsetting_version | 16 | \\n[metadata]\\nsetting_version | 16 |
\\n[values]\\nacceleration_enabled | True | \\n[values]\\nacceleration_enabled | False |
adhesion_type | skirt | adhesion_type | skirt |
adhesion_z_offset | 0 | ||
jerk_enabled | True | jerk_enabled | True |
layer_height | 0.2 | ||
layer_height_0 | 0.32 | layer_height_0 | 0.32 |
print_sequence | all_at_once | print_sequence | all_at_once |
retraction_combing | all | retraction_combing | all |
support_structure | normal | ||
support_enable | False | ||
support_type | buildplate | support_type | buildplate |
보시는 것처럼 한 번 비교를 해 봤다는 정도의 의미지...
별 소득이 없네요... ^^
저는 이 뒷부분에서 대부분의 설정정보를 다 얻을 수 있을 줄 알았는데...
해보니 그 결과가 예상과 다릅니다... ㅎ
- 이전글[내가 프린팅에 실패한 이유] 2. 꼬인 필라멘트 21.01.06
- 다음글두꺼비3D] 큐라의 예상시간 차이때문에 만들었습니다... 21.01.05
ooojjan님의 댓글
ooojjan 작성일
반갑습니다
저 아시죠?^^
수고하셨습니다~^-^
