[TT Oscar] TT 시리즈가 Amazon.com 입점을 준비하고 있습니다. > 자유게시판
작성자 회원 등급하하
댓글 4건 조회 2,227회 작성일 20-10-25 20:34
대표적인 온라인 사이트죠...
Amazon.com 으로 TT OSCAR 가 입점을 하기 위해 준비를 하고 있습니다.
거의 막바지 작업 중이고...
조만간 아마존을 통해서 전세계 Maker 에게 공급을 할 수 있게 될것입니다.
가격대는 최종 확정은 아니지만...
아마존 정책상... 90 - 110 달러 선에서 결정될 듯 합니다.
Features
Arduino MEGA compatible Atmega2560 and FT232 processors are compatible with all RAMPS class firmware
Firmware can use the same configuration as ramps1.4
Easy DISPLAY + SD-CARD connector,RepRapDiscount SmartController compatible pin header on board
All extra pins broken out the same as ramps1.4(AUX-1,AUX-2,AUX-3,Servos1)
3x temperature ADC connectors for thermistors
up to 8 motor driver with easy micro stepping setup (micro switches)
7x PWM capable power mosfet outputs with voltage selector for MainPower.(Bed,Extruder0,Extruder1,Extruder2,Extruder3,Extruder4, Fans)
4 layers PCB, optimize heat dissipation.
6x end stop connectors with power supply Xmin/Xmax/Ymin/Ymax/Zmin/Zmax
3* 5V output, 3* 12V-24V output interface.
Motor Driver : A4988 , DRV8825 , TMC2208 , TMC2209 , TMC2130
Recoverable fuse for short-circuit protection.
Firmware
Upload firmware - Run the Arduino IDE (arduino.exe). or VScode
(Marlin 2.0 or higher)
Select your board - Click on Tools -->Board -->Arduino Mega 2560,
Select your serial port - Click on Tools-->Serial Port-->(select your COM port for the X3 USB, you can check this in Device manager)
On Arduino click File-->Open -- then point to your Marlin Download and select Marlin.pde. With Marlin loaded on the IDE window, click on the tab that says "configuration.h". These are the basic entries that you need to change to get the X3 working.
#define BAUDRATE 250000 //This will work fine for the TT OSCAR
#define MOTHERBOARD 1142 //1142 is for RAMPS which the TT OSCAR is compatible with MOTHERBOARD 1142
#define TEMP_SENSOR_0 1 //If you have the NTC 100K
#define TEMP_SENSOR_1 0
#define TEMP_SENSOR_2 0
#define TEMP_SENSOR_3 0
#define TEMP_SENSOR_4 0
#define TEMP_SENSOR_BED 1 //If you have the NTC 100K
These entries are the only ones you need just to get the MKS Gen running. Once you get it to upload you can now test most features of the board. You will need to tweak the settings on the configuration file for your printer.
중국의 타오바오, 알리익스프레스 등에서도 공급을 해왔었으나, 결국은 아마존이어서 오랜 기간 준비를 해왔었습니다.
아마존을 뚫기 위해서 CE인증도 준비를 했었고....
TT OSCAR 가 무난히 입점이 되면...
다음 순서로는
TT 5Kilo...
다음으로는
TT Uniform Signature..(FDM + SLA 3D프린터로 국내 특허를 받았고, 해외특허 출원중이죠..)
TT Mike...(5색 멀티 컬러)
마지막으로는 5색 멀티 3D프린터 조립키트 인 "yally3D-O2D" 까지 진행을 해보고자 합니다.
국내에서 많은 분들이 중국산 조립키트에 관심을 가지듯...
역으로 우리의 키트가 "최초의 5색 DIY 멀티프린터"로 해외의 고객들과 만나게 될 것입니다.
열심히 하겠습니다..^^
좋은 저녁되십시요.....ㅎㅎ
잘 되었으면 좋겠습니다.
추천 빵..
가자 세계로. ~~ ^.^//
이미지를 다른 곳에 있는 걸 그대로 복사하기로 올리면.. 시간이 지나면 액박 처리 되더라구요.
이건 예전 네이버 에디터도 그랬는데 저희도 그렇네요.
될수 있으면 이미지 누르고 업로드 해서 이미지는 따로 올려주셔야 합니당.. ^.^//
하이님의 댓글의 댓글
하이 작성일
ㅎㅎ
